Hi!
I have problem with dimensions. When I use dimension function in drawings some of dimensions are clearly seen but some of them are not because I ca't move the numbers of dimensions. Could somebody please help me how to move dimensions free (not just horizontal or vertical) or at least how to move numbers of od dimensions.
Thank you
LP Urban
Solved by JDMather. Go to Solution.
Try hitting the Spacebar when placing the dimensions.
Works here?
For the last problem - Styles and Standards Editor.
