Larry If you were using Ordinate dims its unlikely that you would be
dimensioning to a feature not normal to the plane in that set.
You would more than likely make a separate view aligned to the feature and
dimension only that feature in that to a datum, what do you think?
I guess that he is trying to dimension the feature which is not normal to
the view plane by his own admission, and this is where the discrepancy lies?
Like I said in my previous post you need to dimension exactly as it was
constructed?
Unless the feature has been constructed and aligned to some normal axis /
planes, having said that this method would be almost impossible to
accurately set up for machining?
All just theory and superstition without seeing the goods as you said
earlier.
Laurence,
Power is nothing without Control
"Larry Caldwell" wrote in message
news:401e1980_2@newsprd01...
> I think I see what you're getting at. Many shortcomings in the drawing
> module haven't been addressed due, I would guess, to insufficient wining.
I
> would use a section to dim in that instance, but they haven't fixed the
> section command so it can actually do sections correctly either. Maybe
they
> figure eyeball is close enough or they think most people "won't use that"
> and they're working on a Inventor ProSec version.
> ~Larry
> "Billduck" wrote in message
> news:9857380.1075696230197.JavaMail.jive@jiveforum1.autodesk.com...
> > The model holes are cut through the skin directly toward the C/L of the
> barrel. However, in some cases the workplane is rotated say 15 degrees
from
> the XZ workplane.So when I create the views in an IDW I am seeing radial
> holes, the axis of which are not normal to the view created. All of this
is
> as would be expected. But adding a dimension to that hole from the bottom
of
> the barrel doesn't work. I say this because I know the spacing of 2 holes
> along the axis of the barrel is 6" in the model, but does not dimension at
> 6" in the IDW. I think I am going about it incorrectly. Thanks
