hi, can someone tell me how to set off the trim inventor does when one dimensions cross another one?
Mike,
Currently the dimensions do not break when they cross one another. Only when they cross over text.
You might want to place this in the Inventor IdeaStation
hi Cadmanto
my inventor seems to make a trim when two dimension are close and the leader cross the extension line..
see attachement
another thing scott
when i select the dimension with this problem and manually change the arrowhead from by style to oblique it correct the problem..
but if i go in the style editor and make any change, when i go back to the drawing the lines "re"trim themself
Mike,
I am still using 2012, but what I noticed is if I take a dimension and cross over another one the leaders or extention lines only break for text. If I change the leader arrows to oblique the breaks go away, but come back if switched back to original. It appears that breaking dimension lines for other dimension lines is still not in 2013.
Inventor Suite 2012
Windows 7
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
