Hi!
I have one *.idw associated to an ipt. This idw have all dimensions on place and all dimensions are centered and well justified.
But when I change the part, for example, when i increase the overall lenght the dimensions on the idw run out of place and get all messi.
is there any code or way to assure that all dimensions keep centered when the parte resizes?
see attached an printscreen.
Thanks!
Solved by cbenner. Go to Solution.
Try this and see if it helps. Look at Curtis' response to the original idea.
http://forums.autodesk.com/t5/Inventor-IdeaStation/Keep-drawing-dimensions-centered/idi-p/3781771
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
