Inventor Forum
Dimensions out of place when resizing part
2 REPLIES 2
F.Goncalves
335 Views, 2 Replies
Hi!
I have one *.idw associated to an ipt. This idw have all dimensions on place and all dimensions are centered and well justified.
But when I change the part, for example, when i increase the overall lenght the dimensions on the idw run out of place and get all messi.
is there any code or way to assure that all dimensions keep centered when the parte resizes?
see attached an printscreen.
Thanks!
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
F.Goncalves
2 REPLIES 2
F.Goncalves
in reply to: cbenner
This works perfectly!
its so simple..
Thanks a lot!
F.Goncalves
