The issue I have with Inventor 2010 is when i dimension a rectangle to be 44 in wide and 79 in height it becomes a slated rectangle. This event occurs on the work version of Inventor 2010. I have an educational version of Inventor 2010 at home and when I tried this same dimension rectangle at home it didn't have this issue. Is there a setting I need to turn off to fix this> Please help and thank you 🙂
Solved by Curtis_Waguespack. Go to Solution.
Hi harris.1782,
You've likely toggled off your Constraint Inference and/or Constraint Persistence buttons.
See this link:
http://forums.autodesk.com/t5/Autodesk-Inventor/Issue-with-2010-Inventor/td-p/3531308
I hope this helps.
Curtis
