What version of Inventor are you using? I have only 2010 here, so it might be easier in later versions, but i have a fairly simple work-around.
In your idw, create a view-sketch. Project the feature edges (holes, in this case?) that you want to dimension, as well as the centre-point of the pattern.
In the Sketch, create an arc representing every arc-length that you want to dimension. New arc for every dimension you want. Constrain appropriately. Exit sketch.
Dimension the sketched arcs, and with a right-click, change to Arc-Length option.
THEN go back into the sketch, and change all the sketched arcs to Sketch-Only. Exit the sketch, and the arcs are now invisible, but the dimensions stay.
I hope this helps.
If you have read my message through properly, you will discover, that you have described the same way I do it. So thanks a lot, but that is precisely, as we do it now, there is one more way through a “Get Model Sketches”, but her are more difficult to dimensioning on the idw. And this both ways are to primitive and takes to match time.
Lilia Ellgaard
In Inventor 2015 there is a new dimension type available - Arc Length Foreshortened. It is not exactly the same as you are looking for, but just in case you are interested you can check the attached video which demonstrates this type.
Workflow:
1. Select 2 linear edges which define arc angle
2. Using RMB menu change Dimension Type from Angular to Arc Length Foreshortened
3. Select point on arc
4. Place dimension
Oto Kaleja
Thanks a lot.
I'll try, if we can use it after we have updated to Inventor 2016. We run with Inventor 2014 currently. We updates our system every second year.
Kind regards.
Lilia Ellgaard
I'm sorry, you are right. I did not fully read your post. Fear not; I will in the future attempt to not read your posts at all.
