in circle one i have to dimension from the edge of the object ot the closest side of the middle dividing piece, but pecause the points are slightly offset i cannot get the true dimension.
In circle two i have to add more dimensions on the back view of the object but because of the required view i cannot accurately dimension the object
Solved by japike. Go to Solution.
