Is there a way to change the way the dimensions text shows up at arbitrary angles and make them all uniform?
Hi CADMANTOO,
If you press the SPACE bar when the dimension is stilll "floating" does that do what you're needing? Also try Right-clicking to find some options for isometric view dimension placing
I hope this helps.
Curtis
Welcome to the forum.
It looks like the responses you got will help you with your issue, but I had to comment given you have the same screen name as I do.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Ya might have to change to Cadmanone
