Inventor Forum
Dimensioning in an .idw
2 REPLIES 2
Adams.trenton
238 Views, 2 Replies
I need to know how to dimension to a theoretical sharp on bent flanges.  In an .idw it wont snap to the sharp and when a schetch is created for one it does not dimension between them only one or the other.  Any help would be appreciated.  Thank you
2 REPLIES 2
japike
in reply to: Adams.trenton
On a flange that is more or less than 90 degrees, pick your first edge, right click and select intersection, then select the second edge.
Peace,
Jeff
Inventor 2022
Cadmanto
See if this thread helps you out.
http://forums.autodesk.com/t5/Autodesk-Inventor/DIMENSION-TO-VIRTUAL-SHARPS/m-p/3276285#M421834
Best Regards,
Scott McFadden
(Colossians 3:23-25)
