When I place a centerline (or include a workplane from the ipt) is there ANY way to dimension to the intersection of this centerline and the edge of an object?
Like in this image above, I would like a horizontal dim between the vertical centerline and the intersection of the centerline and the edge of the part.
I know that I can create a sketch on the view and project geometry/draw geometry... but that is such a pita.
It would be nice if arcs and circles were selectable with the standard intersection tool (which needs some serious rework anyways). As far as I know, the sketch method is your only solution.
You said you have a work plane, right? How about splitting the cylindrical face with the work plane? It leaves an unsightly scar on your cylinder, but it works:
I guess you could also create a work point in the part at just the spot you need.
That would prolly work for a part (and my example shows a part), but I am actually working with an assembly (weldment).
