Inventor Forum
Dimension Style
1 REPLY 1
KevinPinks7697
156 Views, 1 Reply
Dimension Style
Hello, I am using Inventor 2013 Pro. If I create a new dimension style that has alternate dimensioning. Save it and then go into Object defaults and set the "Linear Dimension" to use this new style, why don't the vertical dimensions update to dual dimensioning like the horizontal dimensions?
1 REPLY 1
Cadmanto
in reply to: KevinPinks7697
In your dimension style what do you have set here?
You might need to set one up for horizontal and one for vertical.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
