Inventor Forum
Dimension spacing when using "Automatic Dimension" in sketch mode
2 REPLIES 2
mikew
245 Views, 2 Replies
Is there any way to automaticly space dimesions when using this command? I use this thing a lot and i end up getting what you see in the attached pic (granted this is extreme given the text boxes). Then i have to individually pick each dim and drag to where i want it.
thanks for any help,
Mike
2 REPLIES 2
in reply to: mikew
Automatic Dimensioning does dimension the sketch, but most oftern does not
preserve any design intent. I never use it except to locate a missing
dimension of constraint quickly. I then Undo and place the dimension
manually.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr. Tel. (260) 399-6615
AIP 2008 SP3, AIP 2009-SP2, IV2010 ProPcCillin AV
AMD 64 x2 3.0 Ghz, 8GB RAM GeForce 9800GT 512MB
XP Pro SP3, XP Pro64 SP2, Windows XP Silver Theme
http://teknigroup.com
JDMather
in reply to: mikew
Never use it. From what I can see you should investigate Feature Patterns rather than sketch patterns, or break up your sketches in to multiple sketches.
