annotation scale only for scale text dimnesion
it is necessary that the size was small balloons or remove
http://s1.ipicture.ru/uploads/20130211/VWetjz9D.png
sorry my english
Zoom all before adding sketch dimensions.
Delete your dimension.
Zoom All
Now add your sketch dimension.
Attach the ipt file here that exhibits this behavior. Something is fishy.
is there another way?
Yes, reply to this thread and attach your ipt file directly here rather than using 3rd party websites.
I don't know how those two dimensions got that way, but if I add new dimensions to your sketch, they look as you would expect.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
This happens all the time when the initial sketch size isn't close to the desired finished size.
I simply dimension to get the correct size, delete the dimension and recreate the dimension or recreate geometry closer to finished size.
In the end - it really doesn't matter exept for the aesthetics of the sketch.
