Inventor Forum
Dimension Shifting
3 REPLIES 3
157 Views, 3 Replies
Dimension Shifting
Hi gang Has anyone had this problem with dimensions
not staying correctly with the view if the view was moved. This has become a real problem lately. I have a rather large IDW with 4 sheets 'D' size. I have made the usual adjustment to the assembly and when I go back to the IDW the views have move but the dimensions did't move with it. Deleting the dimensions and reworking dosen't work because you can't pick a point on the visible view. It tries to diminsion where it used to be. The only fix I have found is to start delete the IDW and start over. (Note: This never happened with 5.30
Dell 530
2g xeon
1g ram
quatro 900
3 REPLIES 3
I have had the same problem.
If you update the views, all should be
OK.
Just select all your views in the browser and klick
on the update-button (the lightningbolt).
Hi
Dell 530
2g xeon
1g ram
quatro 900
Thank You Teun Ham your update worked great. I wounld have never thought if it. I have never used the update command in a IDW and didn't think that it would apply
Again Thanks
jclark
No thanks!
Thank
apply
Again Thanks
jclark
