Inventor Forum
Dimension Rotation
2 REPLIES 2
522 Views, 2 Replies
Dimension Rotation
Hi Everyone
I don't know what I am doing wrong but all I want to do is rotate one dimension. I want to leave all the others alone.
When I am editing my drawing, I double click on the dimension and get the diag box and unfortunately the rotate dimension command along with the degree box is grayed out.
Randy
2 REPLIES 2
mflayler2
You will have to create another dimension style.
Go to the Styles and Standards Editor on the Manage Tab --> Styles and Standards Panel
In the Dimension Area of the left, create a new dimension style and change the settings for the Text Tab --> Orientaion -->Linear to use an In-Line style.
Then select your dimension on the Format Panel at the end of the Annotate Ribbon Tab, select your new dimension style from the list.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
in reply to: mflayler2
Thanks Mark
As always, I greatly appreciate the advice.
Very Respectfully
Randy
