Hmmm ... that seems kind of quirky, no?
~Larry
"Sean Dotson" wrote in message
news:F65EC18316528913F36703A509C71399@in.WebX.maYIadrTaRb...
> Look in CF under same topic.
> In the last sketch there are 4 circles (two of which have been terminated
by
> some lines. Try to dimension the offset distance between the out and next
> circles segments. If you place the dimension within the 5 deg area it
will
> place. If you try to place it outside of the 5 deg the dimension
> disappears. Now do the same with the offset between the outer segment and
> the inside copper band. And again for the offset between the 3rd circle
and
> the 2nd circle segment. All of these dimension must be within the 5deg
> area. Makes for quite a crowded spot.
> You can drag them off after placement but they drag as dims that are
tangent
> at that point and not as true diametrical offsets.
> I don't recall have this limitation in 5.3 (can't switch back at the
moment)
> Sean Dotson, PE
> http://www.sdotson.com
> remove all #s from email
