Hello Everybody,
I have attached a part file and drawing of the same.
The 1'-8" value is above the dim line can I get it below the
dim line as if mirrored about the dimension line.
Please find the images attached for futher clarity
Is there any simple option which I am missing
Solved by mercerc. Go to Solution.
I’ve looked at the file and the dimension styles and the text (unlike just text) can’t be rotated. I’ve created a style of text that is rotated 180 degrees and as text goes it works fine. If I set the text as the text that the dimension style should use it rotates it back to 0 degrees. If you edit the text in the dimension style you will see the text option of rotation is grayed out.
Thanks for the reply
I tried doing what you tried to do.
Its not working for me.
Please correct me if I am wrong
The intent of your post says that we can't achieve that kinda
rotation in the text, correct?
Thanks again
