I'm dimensioning some 'sheet metal' parts in an IDW drawing and a few dimensions attach to geometry fine, but when I select the placement position, it pops up with the following error:
"Create Linear Dimension: problems encountered while executing this command.
One or more of the definition points are no longer attached to the geometry. Drag the dimension definition points to reattach the dimension."
Dragging the point that is no longer attached to any geometry doesn't work at all for angular dimensions (which is where I first saw the problem). Re-doing the dimensions entirely (for linear dimensions) and selecting a line and a point (sometimes in certain order) versus selecting two lines will allow the dimension to stay attached. I've attached a part file for someone else to check and see if it occurs for them as well.
Can anyone telle me why this is occuring and how to fix it?
Thanks Mike, the suppress/dimension/unsupress for CUT1 works.
I'm using the Cut Normal option for these cuts so that when the shop fits the plates up there won't be that little bulge on the corner of the bend that someone will have to grind down in order to fit properly. Since everything is larger than we can get in a plate size and/or fit in the press brake, I have to split the parts up at the corner and cannot use the Corner Seam tool between multiple parts... unless I haven't found that feature yet.
Would be really nice to get a fix for this in an update.
I removed the "solved" for your post Mike, since I ran into another problem for the stair stringers where the unsupress feature doesn't have the same effect as it did on the tread plate. Whatever the Cut Normal option does, attaching dimensions to that cut geometry simply doesn't work in a drawing. See the attached pictures and part file.
Is there someone from Autodesk that can suggest a fix?
Can anyone else suggest a workaround that won't take more time than using the Cut Normal option but gets the same results?
I've escalated it to a Support Issue. Don't hold your breath until next week with all the holidays.
Hello Eddie,
Could you please post the whole dataset including drawing with the culprit dimension? When I open the attached part I get the unresolved referenced file (Laser & X-Ray Sorter Platform - Line 1 - Reference.ipt).
Oto
Thanks for responding. I've attached the additional files you've requested. This continues to happen only when I use the 'Cut Normal' feature option on sheet metal parts. Has anyone else reported this?
Thanks for posting the complete dataset. I have sent this issue to our development team to take a look (case #50762). I haven't seen similar reports yet.
Oto
I have asked our QA engineer to recreate this issue from scratch. However, he was not able to do so, therefore it looks like a dataset specific.
Oto
I just recreated the error using the default templates and a more simplified drawing. Please see the attached.
I would love to hear from someone else that this happens to as well. I hope it's not just on my computer.
Just thought I'd bump this thread again. Anyone experiencing the same problem? Can anyone else reporduce this error?
I was able to recreate the issue. I have attached the files. (Inventor 2015)
Also, the face immediately to the right of the selected line is not selectable for measurement. I don't know if this is related to the unattached dimension issue, but possibly.
Where does this issue stand?
Thank you.
Alex
Hello Alex,
Thanks for the dataset! I have added it to the internal case #50762 so development can take a look. Expectation is that the issue should be fixed in a service pack for Inventor 2016, but that may change.
Oto Kaleja
Hi Oto,
I just have to say... 6 months after the start of this thread (3 months since you first assisted) and the best we can hope for is "should be fixed in a service pack for Inventor 2016"?
Is there no chance for a bugfix for 2015?
