Is there any way to override the dimension line offset value for Individual dimension extension lines?
I would like to know if it is possible to do this in Inventor, in the same way that it can be done in AutoCAD with the DIMEXO or DIMFXL Variables.
Hi Paul,
I think this is what you mean. See attached pic.
As far as I can tell, you are right Paul, that does change it globally. I don't know of a setting that you can just change each extension line individually.
