how do i dimension an illustration view?
Solved by Curtis_Waguespack. Go to Solution.
Solved by CCarreiras. Go to Solution.
Hi Chuck21_Design,
By "illustration view" do you mean a rendered view created in Inventor Studio using the Illustration Render Style?
If so I don't know of a way to add dimensions to that, other than to use Photoshop to merge two images.
If that's not what you meant, you might provide more details or a screen shot to help others understand your question a bit better.
I hope this helps.
Curtis
