Inventor Forum
dimension in illustration view
3 REPLIES 3
267 Views, 3 Replies
how do i dimension an illustration view?
3 REPLIES 3
CCarreiras
Hi!
What!!??
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
Curtis_Waguespack
Hi Chuck21_Design,
By "illustration view" do you mean a rendered view created in Inventor Studio using the Illustration Render Style?
If so I don't know of a way to add dimensions to that, other than to use Photoshop to merge two images.
If that's not what you meant, you might provide more details or a screen shot to help others understand your question a bit better.
I hope this helps.
Curtis
in reply to: Curtis_Waguespack
Thank you for the help Curtis.
