The draft angle is most likely the culprit. You see, because of that, in the view you are trying to dimension the fillet, makes it so the arc is not a circular arc.
Forgive my terminology, the best way I can explain it.
The dimension ability only works if you are looking directly into the arc, which would make it truly circular.
I have attached a picture of what I can only guess is the problem. Looking at the top, a fillet is placed on a normal corner and you can dimension it fine. However, as you can see on the bottom, the fillet has been placed on a drafted face, which in the straight on view, makes it so the curve is not truly circular. The dimension ability will not work on stuff like that as far as I know. You may just have to do it with a regular leader in fill in the value yourself.
Edited by: zma1013 on Jan 26, 2010 2:23 PM
IV2012
Windows XP SP3 32-bit
Intel Core 2 Duo 6400 @ 2.13 GHz
Nvidia Quadro FX 3450/4000 SDI 256MB Vram
2 GB Ram
160GB HDD
