Is there a way to do a jog in a dimension line extention?
Sorry this is not of any help. I would like to do the same thing but cannot find a solution.
I have responded in the hope that this will help to highlight the fact that there are lots of users that require a solution to this problem.
I am currently sketching a jogged line on a drawing view, then using a standard dimension from the sketched line. This is a poor solution as the dimension value has to be manually updated to the correct figure. I have tried to link to a user parameter in the model but cannot set it up so that it will always update depending on the iPart factory member that is active in that particular drawing view.
I hope this gets resolved soon, I would use a jog feature on every drawing that I produce.
Inventor IdeaStation
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
The only thing I can think to do as there is a lack of feature is to sketch a jog, then dimension to this and make a false dimension. Not ideal but will get the job done.
