I just started using Inventor and I have this issue, that whenever I set a dimension in a sketch, the sketch doesn't update to the new dimension until I move my mouse/cursor. Is this normal? Is there any way to change it so it updates as soon as I hit the enter button (after entering a dimension)
Solved by mcgyvr. Go to Solution.
Sounds wierd..like a graphics issue..
What graphics card/driver do you have?
Have you tried to update your graphics card driver?
What are your settings in... tools..application options..hardware tab?
What version of Inventor?
Thanks for the answer. It was a graphics Card Problem. I have both the Intel HD Graphics ans the NVIDIA GT540M, after changing some settings everything is now working well
I have a similar problem, what settings did you change in inventor. although I only have an NVIDIA Quadro 4000M in my laptop
