Personally, I vote that the code for the drawing arc length be copied and
used in the Part model
IMHO.
Bill Bogan
"Larry Caldwell" wrote in message
news:962DDAF94B9E27DF72F57DF1799598B4@in.WebX.maYIadrTaRb...
> Naturally I saw that only after I posted ... Duh! I picked on the dim ...
> sure'nuf ... it was named arc length.
> ~Larry
> "Sean Dotson" wrote in message
> news:7064FE7FB96C3A62932CFE3AC74368D8@in.WebX.maYIadrTaRb...
> > The vertical line is the arc length in both examples. In the first
> example
> > change the angle or radius to get the length. In the second change the
> > length or radius to get the angle...
> > Sean Dotson, PE
> > http://www.sdotson.com
> > remove all #s from email
> > news:3632CB02BE858051864756CCC8D2D404@in.WebX.maYIadrTaRb...
> > > Which one is the arc length? Looks like the leader dim is the radius,
> no?
> > If
> > > you change the angle, it still keeps the same dim.
> > > ~Larry
> > > news:F7066DFE262584F8DDEDF2584945C0F0@in.WebX.maYIadrTaRb...
> > > > oops hit enter too soon...
> > > > The vertical line shows the arc length
> > > > Sean Dotson, PE
> > > > news:381D66E87B7A7998CE253DC130329302@in.WebX.maYIadrTaRb...
> > > > > There is an example in Cf on how to do it in part mode..
> > > > > Sean Dotson, PE
> > > > > "Drew Fulford" wrote in message
> > > > > news:6CA593A9E0B4568E85095008E333208F@in.WebX.maYIadrTaRb...
> > > > > > In an IDW its as easy as a RMB before placing the dim,
> > > > > > In an IPT its not doable without math formulas
> > > > > > - drew
> > > > > > Drew Fulford B.A.Sc. Systems Engineer
> > > > > > Solid Caddgroup Inc. Burlington, Ontario
> > > > > > Tel: (905)331-9670, Fax: (905)331-7280
> > > > > > Corporate: http://www.solidcadcam.com/
> > > > > > Member of the Autodesk Discussion Forum Moderator Program
> > > > > > Visit my MCAD website @ http://www.mymcad.com/
> > > > > > "Brian Mears" wrote in message
> > > > > > news:57DE2AC54F66919B2C27918860694D40@in.WebX.maYIadrTaRb...
> > > > > > > Is it possible in Inventor to dimension an arc's true length?
