I would like to dimension the arc length of a radius in sketch mode and i was wondering if this is possible. I am using Inventor simulation 2010.
Solved by JDMather. Go to Solution.
Solved by PaulMunford. Go to Solution.
Techniques for controlling arc length via parameters have been discussed here in the past - if you can't find the solution post back and I'll see if I still have an old file example.
I put together a post on this that you might find usefull.
I'd CERTAINLY LIKE TO SEE HOW TO DIMENION ARCH LENGTHS IN THE SKETCHES. I've BEEN LOOKING FOR A AHILE AND CANNOT SEEM TO FIND A HOW TO OR FIGURE IT OUT AS OF YET.
-M
http://help.autodesk.com/view/INVNTOR/2017/ENU/?contextId=REDIRECT_ID_SKETCHGENDIM
edit: wrong link above, see this link:
https://forums.autodesk.com/t5/inventor-forum/how-to-dimension-an-arc-length/m-p/5706016#M552950
p.s. it's typically considered poor form to type in ALL CAPS
I hope this helps.
Curtis
