RMB > Vertical Dimension
Duncan
"Humour ... is one man shouting gibberish in the face of authority, and proving by fabricated insanity that nothing could be
as mad as what passes for ordinary living."
(Terence 'Spike' Milligan K.B.E., 1918-2002)
www.autodesk.co.uk/inventorjobs
http://support.microsoft.com/default.aspx/kb/555375
wrote in message news:5866929@discussion.autodesk.com...
Any hints on how to get inventor to be a bit more intuitive, when dragging dims. I'm simply needing a vertical dim, in a
sketch, to locate a notch, but inventor won't allow me to drag vertically, only horizontally. I try to dim from the tip point
of the notch to the center line of the part; simple dim; but I'll spend as much time fooling with one simple dim, as I did to
do the entire drawing. Is there any way to suggest to it I need a vertical dim? Thanks for any help in advance.
Rob d.
