Inventor Forum
Dim to sketch line in idw view
5 REPLIES 5
483 Views, 5 Replies
I've placed a scketch in a view in my idw.
In the idw, I was once able to dimension between a visible view line and a visible scketch line, but not now.
Currently using Prof 2013 64 bit
J.
5 REPLIES 5
JDMather
You must Project Geometry the drawing entity that you want to dimension the sketch line to.
Attach your file here if you can't figure it out.
(of course the first step is to make sure that you do in fact have a view level sketch and not a sheet level sketch)
Cancel comment. I found the problem.
JDMather
You should post solution so that others who search on this problem find the solution.
in reply to: JDMather
Error is in the model. Have not fully work out the solution. Didn't want others to spend time on it.
Model was not completely square to origin plans resulting in a slightly skewed view image that was affecting dimensioning in idw.
