I've placed a scketch in a view in my idw.
In the idw, I was once able to dimension between a visible view line and a visible scketch line, but not now.
Currently using Prof 2013 64 bit
J.
You must Project Geometry the drawing entity that you want to dimension the sketch line to.
Attach your file here if you can't figure it out.
(of course the first step is to make sure that you do in fact have a view level sketch and not a sheet level sketch)
@Anonymous wrote:
Cancel comment. I found the problem.
You should post solution so that others who search on this problem find the solution.
