Inventor General Discussion
Member
gta3005
Message 1 of 6 (702 Views)
Difficulty with flat Pattern on ellipse
702 Views, 5 Replies
02-14-2013 07:55 AM
First post here so hopefully it works out well. I'm having difficulty with a sheet metal part creating a flat pattern for it. The shape is an ellipse with the dimmensions shown in the second picture. When I attempt to create a flat pattern it just shows the side of the part. The sheet metal defaults are correct for the part and it was ripped to created a base point for the pattern. I need to create a DXF for manufacture. I would just use the flat pattern it gives me and mirror it twice to create a pattern but it doesnt factor in the radius of the part. Any thought on how to create a correct flat pattern for this item?
I have to run - so not time to finish the part, but you get the idea
see attached
JDMather
Message 2 of 6 (684 Views)
Re: Difficulty with flat Pattern on ellipse
02-14-2013 07:59 AM in reply to: gta3005
What version of Inventor?
Do not sketch the thickness - Inventor will do that for you.
Only need one ellipse.
Contoured Flange (from the sheet metal tools).
Rip
Flat Pattern.
Attach your ipt file here.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Member
gta3005
Message 3 of 6 (679 Views)
02-14-2013 08:07 AM in reply to: JDMather
Inventor Professional 2013
Thanks for the quick response
JDMather
Message 4 of 6 (669 Views)
02-14-2013 08:09 AM in reply to: gta3005
Let me give that another try - looks like Contoured Flange won't select an ellipse.   (and you left out some inportant information about the trims)
JDMather
Message 5 of 6 (654 Views)
02-14-2013 08:14 AM in reply to: JDMather
see attached
Member
gta3005
Message 6 of 6 (644 Views)
02-14-2013 08:17 AM in reply to: JDMather
Thanks so much
