Inventor Forum
Difficulty with expanding portion of design
3 REPLIES 3
N4n45h1
393 Views, 3 Replies
I'm looking for some direction to follow to modify an existing design. I am trying to thicken left and right walls in order to make the inner section narrower. However, none of my attempts have been successful. I am not looking for learning materials for CAD, but rather a solution to this specific problem. I am not experienced in CAD but simply need to solve this one problem in order to move forward.
3 REPLIES 3
blair
in reply to: N4n45h1
This appears to be done in Autodesk Fusion. You should be able to select the inside side/face and use the "Push/Pull tool to thicken the desired face.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
N4n45h1
Thanks for your reply.
I have tried to use the push/pull function and receive the error, "Modeling Error:  Failed to propagate the blend face graph."
I have also tried using the extrude function and receive a different error, "Modeling Error: Extrude operation failed."
Do you have any other ideas?
blair
I don't have Fusion on my system, you might try the Fusion forum: http://forums.autodesk.com/t5/Get-Help-with-Fusion-360/bd-p/123 It will be the Fusion 360 but should still work for you.
Delta Tau Chi ΔΤΧ
