Hi, I am currently on Inventor 2014. My colleague recently upgraded to Inventor 2015. I seem to have trouble opening any of his files on my computer. When I go to the "Open" screen it will show the file and generate a small preview in the windo but when it tires to open the big file, it comes up in the dialouge box with yellow exclamation marks and says
Error in reading RSe Stream
Any ideas? Thanks, in advance.
Eric
Solved by DarrenP. Go to Solution.
Solved by LT.Rusty. Go to Solution.
There's no backwards compatibility in Inventor-native file formats.
You need to both be using the same version, if you want to share files back and forth.
Rusty
you can do a save as a .stp file and open it in 2014
but you will lose all feature history
there is no workaround for this
DarrenP
