Inventor General Discussion
Valued Contributor
jeff.noel
Message 1 of 4 (1,120 Views)
Difficulty converting STP/IGS to IPT
1120 Views, 3 Replies
11-30-2012 01:52 PM
I have a file from a suppliers website that comes in either STP or IGES files.  I'm trying to convert it into an IPT to be useable in one of my models, but I don't seem to be having any luck with it.  I don't convert many STP/IGS files, and most of the time when I do they just work without many issues.
I can get the model to look proper in this one, its just that working with it makes Inventor run incredibly slow.  When I want to add an assembly to a drawing that is using this model, it takes several minutes just to place the view, removing the part and it works quickly again.
The part can be downloaded here:
http://sealcocvp.com/home/dl/wabco/parts/4005001010.zip
I was wondering if anyone would be able to share some guidance on how to best get this file to a useable IPT file, as I can't have it grinding my computer to a halt every time I use the model.  Thanks for any help!
I was able to import the dwg and it seems to be usable. There are errors in some of the parts (nuts mostly) but they seem minor and probably not worth trying to fix.
I didn't add it to a higher assembly but it's iam responds to various commands well.
Distinguished Mentor
rdyson
Message 2 of 4 (1,115 Views)
Re: Difficulty converting STP/IGS to IPT
11-30-2012 02:19 PM in reply to: jeff.noel
JDMather
Message 3 of 4 (1,108 Views)
11-30-2012 02:31 PM in reply to: jeff.noel
jeff.noel wrote:
I was wondering if anyone would be able to share some guidance on how to best get this file to a useable IPT file, ...
http://home.pct.edu/~jmather/AU2008/ML205-1P%20Mather.pdf
You didn't indicate what version of Inventor you are using.
I still use the Construction Environment rather than the new Repair Environment.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
Valued Contributor
jeff.noel
Message 4 of 4 (1,107 Views)
11-30-2012 02:31 PM in reply to: rdyson
D'oh, I never work with 3D DWG's, so when I saw the DWG I just assumed it was a 2D Drawing (must be Friday afternoon).  I've loaded it up and it works great, it is the way to go.  Thanks for your help!
