Inventor General Discussion
WILLIAMF
Message 11 of 18 (237 Views)
Re: Difficult request from boss. Need help!
10-17-2012 03:54 AM in reply to: WILLIAMF
The letters look something like the attached, about an inch high.I need to model that using the .280 x .140 rectanglar profle.
Ha this should be fun!
Dell Precision T3500
Windows 7 Pro
Quad Core Intel Xeon
6 Gb SDRam
NVIDIA Quadro
Product Design Suite 2014 Premium
*Expert Elite*
JDMather
Message 12 of 18 (213 Views)
10-17-2012 05:07 AM in reply to: WILLIAMF
This is how I would create the 3D sketches.
http://home.pct.edu/~jmather/content/DSG322/Inventor%20Tutorials/Inventor%2011%20Tutorial%207.pdf
I estimate it would take me about 8 hrs to complete the project (unfortunately I don't have 8 hrs to spare, but I might be able to get at least one letter).
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
WILLIAMF
Message 13 of 18 (207 Views)
10-17-2012 05:11 AM in reply to: WILLIAMF
I think a while back I did that tutorial but I'm rusty with this kind of modeling since there is no need for it here. i'll go thru it to refresh my skills.
One letter would be great to give me a starting point.
Windows 7 Pro
6 Gb SDRam
NVIDIA Quadro
Valued Mentor
mpatchus
Message 14 of 18 (171 Views)
10-17-2012 06:40 AM in reply to: WILLIAMF
You could also try taking a straight length and use the bend tool to maniuplate it.
You obviously can't do the entire word with one continuous piece, but you could make multiple pieces which could be welded together.
Mike Patchus
Inventor 2012 SP3 ~ Vault Pro 2013
Lenovo D20 Workstation Intel Xenon E5640@2.67GHz (2)
Win 7, 24gb RAM, NVIDIA Quadro FX 3800
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. :smileyhappy:
WILLIAMF
Message 15 of 18 (161 Views)
10-17-2012 06:54 AM in reply to: WILLIAMF
Thats interesting and fairly simple idea. just need to plot the script font for the points so it looks like an L.
Windows 7 Pro
6 Gb SDRam
NVIDIA Quadro
Valued Contributor
machiel.veldkamp
Message 16 of 18 (149 Views)
10-17-2012 07:06 AM in reply to: WILLIAMF
Don't have enough time to fully explain but I hope you understand this methode:
More about that tomorrow (maybe)
___________________________
Inventor 2012 lastest service pack
RAM: 24GB DDR3 / CPU: Intel Xeon W3690 @3.47Ghz
Video: NVidia GeForce 680/ HDD: 15.7K
Windows 7 Pro 64-bit
WILLIAMF
Message 17 of 18 (142 Views)
10-17-2012 07:13 AM in reply to: WILLIAMF
the sweep cant intersect, it needs to below or above at the intersect point.
Thanks for the idea and time
Windows 7 Pro
6 Gb SDRam
NVIDIA Quadro
Product Support
4donwan4
Message 18 of 18 (79 Views)
10-19-2012 06:32 AM in reply to: WILLIAMF
Keeping on the theme of everyone's posts. Just something to consider and not sure if it applies here. A continious 3D path would not work for an upper case S in script as it self intersects. I would try to create each letter as a part file. Start a sketch by overlaying the script letter in the hieght you want. Then trace a 2D path around it. Then try sweeping that. Connect each letter with constraints in Assembly mode to get exact cuts to lining it up. Junst my two cents.
Post to the Community
New Post
Need installation help?
