Using the Elbow .ipt file is there any way of setting up a table for different sizes?Change sizes from a table within the .ipt file and the part updates..
Currently the part is named Elbow.If this was your part how would you name?
Regards
Harold
version: 2013
Solved by Mario428. Go to Solution.
Very simple to do, make your elbow an I-part and put all the relevant dimensions in the table.
One click gets you the size elbow you need
See attached for quick and dirty example
If you are going to use it in Tube and Pipe make sure you author it and publish it to Content Center. it's much easier to change size than to replace from disk.
