Inventor Forum
different size pipe elbows
3 REPLIES 3
harold_kennedy
289 Views, 3 Replies
Using the Elbow  .ipt file is there any way of setting up a table for different sizes?Change sizes from a table within the .ipt file and the part updates..
Currently the part is named Elbow.If this was your part how would you name?
Regards
Harold
version: 2013
3 REPLIES 3
Mario428
in reply to: harold_kennedy
Very simple to do, make your elbow an I-part and put all the relevant dimensions in the table.
One click gets you the size elbow you need
See attached for quick and dirty example
harold_kennedy
in reply to: Mario428
Thanks Mario
salariua
If you are going to use it in Tube and Pipe make sure you author it and publish it to Content Center. it's much easier to change size than to replace from disk.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
