Hi All
Is there a quick way make Multiple Different Size Dimension & Text Style in Style & Standards Editor?
. . Like a fast way to define New Style Standards for multiple sheet sizes in the same ipj Design Data folder?
Currently I am using ‘Replace’ and ‘Purge’ to substitute the Existing Standard ‘Label Text (ISO)’ for e.g., in my New Standard, for ‘My Custom Size 20mm Label Text (ISO)’. I want to do the same to make a ‘Size 3mm’ Style Standard in a similar manner.
My aim is not have to change the defaults manually each time I flick from Small to Large Sheet formats in the same idw.
Am I on the right track?
Is there a way to confirm that I am writing to the Style & Standards in my Working Folder, other than the ipj ‘Folder options’ setting? Or is ‘My’ Style Lib info written in the ipj and can’t be verified as such.
Thanks MatB
. . It seems the main functionality or hidden golden function of Styles,
comes from the 'Active Object Defaults' pulldown,
in the 'Objects Defaults' tab on the RHS in the S&S Editor,
that dictate what Default Settings are active
from the ones u made on the LHS Objects.
Excellent Inventor. . Thanks K2 Tech n Crew n 'retrievetech' for the vid
