Inventor Forum
different shell thicknesses
2 REPLIES 2
richard_cirillo
1138 Views, 2 Replies
What are the steps to having different thickness in as part file.I tried the unique thickness but could bot get it to work
1. Revolution 1 - 5mm
2. Revolution 2 - 2mm
3. Extrusion 1 - 2mm
I try selecting different faces but no success
Cheers
2 REPLIES 2
JDMather
in reply to: richard_cirillo
If it had worked - it would have to add the Fillets 3 and 4 that I added.
I am not sure you intended these - so if not, simply do the Shell feature before Fillets 1 and 2.
rdyson
in reply to: JDMather
This also works (at least in 2015):
But it did require a delete face to cleanup the internal fillet:
PDSU 2016
