Inventor Forum
Different physical material properties.
6 REPLIES 6
russellh
532 Views, 6 Replies
On some parts when I go to iProperties/ Physical/ Material I get maybe 40 different options. On other parts I only get 14 options. How can I get all the options on all of my parts?
Autodesk Inventor 2011
AutoCAD Mechanical 2011
6 REPLIES 6
mcgyvr
in reply to: russellh
currently you are using local styles.. You should look into turning on/maintaining a single style library.
russellh
in reply to: mcgyvr
Thanks, sounds good, but I have it turned off because of a error message I get when opening my drawing template. So now you've given me another problem to chase down.
mcgyvr
I'm betting the error is because the styles in the template don't match the style library..Which is to be expected till you fix that.
russellh
in reply to: mcgyvr
Yes, that's the problem. I need my dimensions to be set to inch, 4 decimal places. How do I fix this in the style library?
mcgyvr
set use style library to yes..open your template..get everything the way you want it and save to style library.. save/close template.. Problem solved.
You can't just change stuff in the template and forget to also save to style library..
russellh
in reply to: mcgyvr
Well I think I got everything happy now. It all appears to work as I want. Thanks.
