Inventor General Discussion
Distinguished Contributor
sps_cad_guy
Message 1 of 3 (171 Views)
different degree flange question.
171 Views, 2 Replies
01-16-2013 08:58 AM
I've attached a pdf of a part I'm making the flat pattern for.
The pdf is from our customer, and I already know it's not shown correctly, views wrong, etc.
One bend is 90 degrees and the other is 88 degrees.
What I'm having trouble with, is when I go to put flanges on my part, the corner does not come out as it should be.
The long flange does not have the 2 degrees of material added to it, and even though I have told it to tear the corner, it still puts a big relief when I put the second flange on.
I have searched the help and can't seem to find what I'm looking for.
Thank you very much for your help.
Lenovo Think Pad
Windows 7 SP 1
64 Bit.
Inventor 2013
ACAD Mechanical 2013
Hi sps_cad_guy,
Attached is a quick example file.
There might be more efficient ways to get the same result but this is what came to mind, and should serve as an example of some of the tools that can be used.
I hope this helps.
Curtis
Curtis_Waguespack
Message 2 of 3 (161 Views)
Re: different degree flange question.
01-16-2013 09:17 AM in reply to: sps_cad_guy
Hi sps_cad_guy,
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
sps_cad_guy
Message 3 of 3 (155 Views)
01-16-2013 09:20 AM in reply to: Curtis_Waguespack
Thank you so much Curtis!
That looks perfect.
I knew there had to be an easier way to do it that what I was doing.
Thanks again for your help.
Lenovo Think Pad
Windows 7 SP 1
64 Bit.
Inventor 2013
