Inventor General Discussion
New Member
sartorimartin
Message 1 of 2 (142 Views)
Diferences in measurements between partlist and drawing
142 Views, 1 Replies
07-19-2012 06:29 AM
To all,
I've done a 3D frame in Inventor 2012 and after doing a 2D with a partlist chart I found differences between lengths. The length of the part list was the first one, the frame was modified and the partlist didnt update.
Found out that the d18 parameter was a fixed number. I managed to change it manually by changing the G_L parameter to d18 (Using PNU, image attached).
How can I set up my inventor to update the part length automatically?
Something with the family properties maybe?
Thanks for your help.
Martin.
New Member
sartorimartin
Message 2 of 2 (128 Views)
Re: Diferences in measurements between partlist and drawing
07-19-2012 10:57 AM in reply to: sartorimartin
