Inventor General Discussion
Distinguished Contributor
6 Kudos
Post 1 of 6
Diameter symbol in text
726 Views, 5 Replies
02-25-2006 02:57 PM
Sometimes when revising my drawings, I would like to have a diameter symbol in my revision history block which I created in a similar method as my title block. In MCAD, we could use %%c,%%d for different symbols. Is there anything in Inventor like this
Thx
Kev
2 Kudos
Post 2 of 6
Re: Diameter symbol in text
02-25-2006 04:40 PM in reply to: KevinPinks7697
Whole list of special characters under the degree symbol.
Or by keyboard Alt 0216 Ø
For more check the Windows Character Map under Start Programs Accessories.
*Michael Puschner
Post 3 of 6
02-26-2006 04:15 AM in reply to: KevinPinks7697
In fact Alt 0216 is not the diameter symbol but the Latin capital letter O
with stroke. The letter O with this diacritic is a common Danish and
Norwegian umlaut and may look very different from the diameter sign in many
fonts. The diameter sign is Alt 8960. It's absent in most fonts though.
Michael Puschner
www.scholle.de
schrieb im Newsbeitrag news:5096127@discussion.autodesk.com...
*Troy Grose
Post 4 of 6
02-26-2006 12:38 PM in reply to: KevinPinks7697
Wow theres a bunch of info I didn't expect to get in the IV newsgroup
6 Kudos
Post 5 of 6
03-01-2006 06:12 AM in reply to: KevinPinks7697
Not available in the edit attribute text box.
Thx anyway
Kev
Member
0 Kudos
Post 6 of 6
03-07-2006 08:29 AM in reply to: KevinPinks7697
unfortunately using the Symbols available from the Format Text Window will shift the line text down and one ends up with unevenly spaced line text because these symbols use a different font. To remedy this Autodesk
recommended to use Alt-0176 for Degrees, Alt-0177 for Plus/Minus, Alt-0216 for Diameter.Note you must use the numbers from the numeric keypad on the right side of the keyboard. Press and hold ALT key, type in the four numbers and then let go ALT key.
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
