Inventor Forum
Diameter Dimensions in Sketches
3 REPLIES 3
Cadmanto
2069 Views, 3 Replies
When I create a sketch for a revolved feature, how does one create a diameter dimension
instead of a radius dimension?  While it is nice that you dont need an axis to revolve around,
I am used to having one and when I select the axis then the outer edge and drag the dimension
to the opposite side of the axis from which the outside edge is it automatically creates the diameter
dimension.  In the INventor sketch mode this is not happening.
Best Regards,
Scott McFadden
(Colossians 3:23-25)
3 REPLIES 3
Cadmanto
in reply to: Cadmanto
Never mind, I figured it out.  Didn't realize in order to accomplish this one still needs to create a centerline.
Best Regards,
Scott McFadden
cbenner
In the sketch, select or create a line, or datum (or project geometry as we discussed in oyur other post) which will serve as your axis.... you can then turn that into a "centerline".  If you dimension to that centerline, your dimensions will become diameters.  The other way to do this without creating a centerline is to select your dimension entities, and before you drop the dimension, right click.  You should see choices for "linear radius" and "linear diameter".
Cadmanto
in reply to: cbenner
Thank you.  I think I figured it out based on what you showed me.
Man, is that a lot of steps!!! Smiley Sad
Seems to me this could be made simpler.
Best Regards,
Scott McFadden
