I have a tutorial on Macros on my site.
"Macros for Non Programmers"
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Gary Cook" wrote in message
news:408718c9$1_1@newsprd01...
> Wrong forum, I know, but a quick VBA fer dummies question: How do you
turn
> these code fragments into something you can load, and how do you load
them?
> Save as *.ivb, and run from there? Documentation's a little vague on the
> basic basics.
> TIA.
> "Kent Keller" wrote in message
> news:4086fdd4$1_1@newsprd01...
> > Sounds like you have made exactly what the example in help shows. This
> will
> > also give you the dropdown so you can select any file if you want.
> > oFileDlg.Filter = "Inventor Files (*.iam;*.ipt)|*.iam;*.ipt|All
Files
> > In the future you may find more information or responses by posting
> > future VBA related questions in the following discussion group:
> > Web
> > http://discussion.autodesk.com/forum.jspa?forumID=120
> > Newsreader
> > news://discussion.autodesk.com/autodesk.inventor.customization
> > "chaseling" wrote in message
> > news:24967376.1082587834571.JavaMail.jive@jiveforum2.autodesk.com...
> > > I have made a dialog box that allows file selection, however, the
filter
> I
> > have is set up for iam files, how can I change this to work for iam AND
> ipt
> > files.
> > > Thanks.
