Stephen,
If I understand you correctly, you need a way to easily change the name
of components (pats) in an assembly, after it is finished. You can do this
quite easily in Design Assistant. From your desktop; 'start' 'programs'
'inventor 6' 'design assistant'.
You then need to open the assembly (don't have it, or any components
open in Inventor) and click on the manage button. You can them rename any
components you need. Don't forget to click the save button when you are
done.
hope this helps,
kevin
"stephen r" wrote in message
news:886A92E3F657DFF088368CB1D18BC440@in.WebX.maYIadrTaRb...
> When we work in mechanical desktop, we create new assemblies with the
parts
> local, and named with temporary names (i.e.. bracket, plate 1, plate 2...
> etc. etc.). When we are sure we will use the new assembly, we go through
it
> and change each part name to official part numbers (i.e.. 1234567), then
> externalize the parts and assemblies as necessary. So we end up with the
> files having the same name as the part number, not "bracket.dwg" but
> "1234567.dwg".
> So, Inventor wants you to name each part as created. I understand the
> segmented database thing and the reason why it needs each part named right
> away (no local or external parts like MDT). My question is, during the
> developmental part of an assembly, when you are not sure you will use it
in
> it's initial configuration, you may have an assembly with parts named
> bracket, plate etc. etc.. So when you decide the assembly is excellent
and
> you want to use it, how do you go about changing the part names to
official
> names if they are already saved as files on the network or local hard
drive?
> We have been saving each manufactured part with a unique number per our
> company naming convention with desktop, but we can easily change the part
> name (number) when a part is local. Maybe a different technique is used
> for Inventor?
> I briefly looked at Design assistant, which allowed me to update the Part
> Number field under the project tab of an individual part, but I couldn't
> find anything that lets you change the name of the stored file.
> Thanks for your time.
> Stephen R.
