Inventor Forum
determine size of louver
6 REPLIES 6
skyngu
474 Views, 6 Replies
hi,
is there any tool in inventor that can determine size of louver or quantity of louver base on heat generated?
we are designing a sheet metal box. we need to find out how many louvers we need.
thanks
Autodesk Inventor Professional 2019
6 REPLIES 6
JDMather
in reply to: skyngu
I think you will need to use Autodesk Simulation for that analysis.
http://forums.autodesk.com/t5/Autodesk-Simulation/ct-p/206
in reply to: skyngu
I am interested in how to caculate the heat generated.
Is it natural ventilation or forced ventilation with a fan?
Peter
JDMather
Wrong forum - you should post this question in the Autodesk Simulation forum.
There is a tutorial in Autodesk Simulation that should answer this question.
skyngu
in reply to: JDMather
it is natural ventilation.
jdmather
we dont have autodesk simulation. I will try other ways. thanks
JDMather
in reply to: skyngu
If you use the Grill function on the Plastics Features tab it will show you the flow area, but you must first calculate the required flow area and the Grill would just give you the opening - you would still need to create the louvers.
Cool. Didn't notice this grill button before.
