Inventor Forum
Determine Area of sheet metal
1 REPLY 1
nknehme
664 Views, 1 Reply
IV10 SP2
Is there an easy way to get the Flat pattern area into the parts list through one of the parameters. Do I have to create a parameter and calculate that using the Bend allownance or is it straight forward.
- The Area shown in the iProperties-Physical-General Properties. Is this area the total area on both sides of the sheet metal part. Is dividing this area by 1/2 gives you the Flat pattern area taking the Bend allowance into consideration ???
1 REPLY 1
in reply to: nknehme
forward.
The area displayed there is the total surface
area of the sheet metal part in its folded state.  If the flat pattern is a
simple rectangle, the area displayed is the sum of the areas of all six
faces.  If the part is much larger than the thickness of the sheetmetal,
dividing by 2 would produce a reasonable approximation of the flat pattern
area.
Brian R.
Iwaskewycz
style="FONT-SIZE: 14pt; FONT-FAMILY: Verdana">CAD Systems
Manager
href="http://www.corefurnace.com/">Core Furnace Systems
