Why is it different between F-F and G-G.
I want G-G like a F-F.
But Detail view is half.
Edit the view and toggle the section setting off in the attached pic. You can choose whether you want sections, breaks and breakouts to be show in views down the line.
You need to edit the view that is only half there and turn the setting off in that view not in the detail view it was pulled from.
Attach part and drawing here... Inventor 2012?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
It's a funny behaviour. I have made a small test and it seems you can make F-F look like G-G but not the other way around.
Strictly speaking F-F section should be showing the half part as it is affected by two sections: A-A and F-F. This is not happening in section F-F because in the Drawing View, Display Options, Section is unchecked in the Cut Inheritance box. So the view is forgetting it is affected by section A-A.
By checking it you can get F-F to look like G-G.
But when you go to detail view B and section G the Cut Inheritance options are deactivated, so that is why you cannot make G-G look like F-F.
I have made this check with Inventor 2015.
Best regards
