Hi there,
I have a drawing which has model sketches included. I have also included the model sketch in a detail view.
This all works fine in Inventor. But when I export the drawing to an AutoCAD dwg the sketch lines in the detail view go wonky. The drawing shows the full lines, they are not trimmed to detail view.
Does anyone have a solution to this? Am I doing something wrong?
thanks,
John
Ps. I have attached the part file, Inventor dwg and AutoCAD dwg
Solved by johnsonshiue. Go to Solution.
Hi! I am not able to reproduce the behavior on Inventor 2017. What Inventor release are you on?
Many thanks!
thanks,
we're currently transitioning to 2017, but I ran a test and it seemed to work 🙂
cheers,
John
